So yesterday I spent the most of the day taking apart the engine to get to the knock sensors. While doing so, I checked all of the wiring to see if there’s anything abnormal but everything seemed fine. Once I took the manifold out I noticed that the head gasket was leaking. So I ended up taking off the valve cover and tightening all the bolts holding the head. Hopefully that fixed it lol. The manifold gasket was pretty bad as well and there was a lot of build up inside the manifold. Is it carbon build up? Wasn’t sure if that’s normal or not so I ended up taking out the manifold and cleaning it thoroughly.
While there, I took out the injectors and cleaned them as well. It seemed like some of the leaking oil passed through the injector o rings? Or something else happened? Either way, I cleaned up the manifold, injectors, replaced BOTH knock sensors, replaced intake and exhaust manifold gaskets and put it all back together.
Once I was done, I test drove the car for well over an hour and another hour this morning. So far, it seems like the problem is gone. And hopefully it stays that way! Bad knock sensor was likely the cause. I’m not sure cleaning the carbon build up and putting new gaskets would do anything lol. I’ll keep everyone updated.
