Hello all. I have owned my 2008 AWD HL for 4 months now, and I love it. It is approaching 91k miles, and I bought it around 3k miles ago.
According to Toyota using my VIN, this car underwent major engine work with just under 7k miles in 2009. I'm hoping it's a good thing. Customer brought it in hearing engine rattle. The car was built in Japan in August 08.
See below for all the parts replaced.
7/2009 ENGINE CONTROL MODULE
Parts
Name
Part # Qty
COVER SUB-ASSY, CYLI 11201-0P020 1
GEAR ASSY, CAMSHAFT 13080-0P040 1
FIPG OIL PAN 0295-00103 1
SUPER LONG LIFE COOL 00272-SLLC2 2
HOUSING SUB-ASSY, CA 11103-0P014 1
CAMSHAFT SUB-ASSY, N 13502-0P021 1
GEAR ASSY, CAMSHAFT 13050-0P070 1
GASKET, AIR SURGE TA 17176-0P020 3
GASKET, INTAKE MANIF 17177-0P020 1
GASKET, INTAKE MANIF 17178-0P020 1
GASKET, CAMSHAFT BEA 11159-0P010 4
GASKET 90430-A0001 2
GASKET 90430-12031 1
GASKET, OIL STRAINER 15147-0P020 1
GASKET, OIL PAN 12151-0P010 2
RING, O 96721-19010 1
RING, O 90301-12018 1
GASKET, OIL PUMP 15193-0P010 1
GASKET, CYLINDER HEA 11213-0P010 1
GASKET, CYLINDER HEA 11214-0P040 1
GASKET 90430-16016 2
GASKET 90430-16012 4
SEAL, TYPE T OIL 90311-A0005 1
GASKET, TIMING CHAIN 11328-0P010 1
RING, O 96721-24021 1
RING, O 90301-79006 1
RING, O 96723-35028 1
GASKET, WATER INLET 16325-31010 1
GASKET, EXHAUST PIPE 90080-43036 1
REPLACEABLE ELEMENT 04152-YZZA1 1
GASKET, WATER PUMP 16271-0P010 1
HEAD SUB-ASSY, CYLIN 11101-39535 1
GASKET, CYLINDER HEA 11115-31080 1
GASKET, EXHAUST MANI 17173-0P020 1
SEAL, VALVE STEM OIL 90080-31043 6
SEAL, VALVE STEM OIL 90080-31046 6
FIPG OIL PAN 00295-00103 2
It is the Limited Trim and in very good condition. I was just curious if those on here in the know would have purchased this car knowing this is part of the car's history. Water pump was done at around 55k, and nothing really major that I can tell. Oil changes and other maintenance seems to check out.
Thanks all.
Have a good day and stay safe!
Pat.
Parts
Name
Part # Qty
Thanks all.
Pat.
