Thanks for the info. My issue isn't that there is a difference in temp one side vs. the other.
The issue is that when the fan dial is in neutral territory (i.e. in the middle, between blue and red), and the AC is off, the air is still warm (i.e., warmer than outside/ambient temperature).
Dialing it further into the blue/cool territory, the air does cool down, but not until it's 1/2 of the way or more into the blue territory.
Dialing it to max AC, the AC kicks in/on automatically.
Beyond the neutral/middle position to the right/red area, the air gets progressively warmer as it should.
But again, the issue is it's too warm in the middle position and doesn't get cooler until quite a bit into the blue.
I'm pretty sure it had been cooler in the middle position and didn't have to go as far into the blue to get cool.
The AC & heat both seem to work fine.
Some other things:
I'm dealing with mice or chipmunks in the cabin filter with a bunch of material in the blower. I've cleaned the filter and removed the material from the blower.
I am waiting for a new filter.
I imagine it could be related. Maybe some nest material is blocking the operation of something HVAC related?
I'm going to try to put wire mesh over the air intake under the cowl as well as peppermint oil on the cabin filter and around the engine.
Hopefully they haven't eaten any wires yet.
I've read setting the controls to recirculate keeps certain doors closed that could keep mice out but have also read they default to closed when the car is off.
Can anyone clarify?
I've read in some places that issues like this (i.e. HVAC controls not working as they should) could be related to the damper servo, which looks to be at least 2 parts - 871060E140 & 8710607140.
The little motor (8710607140) is less expensive and seems like it would be easier to replace than the piece (871060E140) it fits onto.
Most videos I've seen replace this (8710607140) little motor piece to fix similar issues.
Does anyone know where the blend door servo is for a 2011 Camry LE VIN start w/ 4?
Some videos show passenger side, others show driver or both, I think for dual control systems. My car is not a dual control system.
Or maybe it's the control unit with the dials? I think I've read they could go bad too?
It would be great to hear from someone who has had or fixed, or knows how to fix, similar issues.
Thanks!
