2012 Camry SE V6 No Crank
1 reading
3K views 21 replies 6 participants last post by  henrydedrick
2012 Toyota Camry SE V6 keyless entry push to start. Alternator wore out so I changed it. It couldn't put out more than 10v. Had the battery off for over 12 hours (charging the entire time even though it never died. The lowest it got was 11.2v. When I got everything back together, my fob stopped working. I sit in the car with the fob, the security light is flashing, I press the start button, the steering wheel unlocks and the dash lights up for a second before it turns off (key symbol on dash flashing orange), I hold the fob to the start button and the dash lights up like you turned a key on the the first click. No radio, power windows don't work, no ac. First acc position I think. When the dash lights up, the key symbol on the dash turns green and the security light stops blinking. Fobs never work the doors, engine never cranks. All batteries are either new or charged. All the fuses I can find are good. I've tried every reset I can find online and nothing works. Two different Autel scanners couldn't do it. They both said the rest I needed was through the (engine) ECU and that they couldn't communicate with it. Is this something I need a Toyota tech to plug in a Toyota computer to reset? I'd hate to give them $200+ just to hit a reset button. I know the fobs are good. I know the battery is good. Is there a way I cant use a good multimeter to verify my ECU isn't toast? Is this just the ant-theft/immobilizer? I'm very mechanically inclined so this is driving me crazy. Thanks for any help in advance.
This is a big clue that your 12V battery is likely old, weak or worn out and depleted beyond hope. It is likely why the alternator wore out--it was trying to charge a sulfated battery that absorbed huge amounts of current but failed to effectively charge the cells. This was pulling the alternator voltage down.
You would need to measure specific gravity of the electrolyte or perform a capacity test to verify the condition of the 12V battery.
This is a common issue and there are hundreds of posts such as yours on this and other car forums.
Put a voltmeter on the battery with key OFF, then with key ON, then while cranking. 3 voltages to report back.
This could be a first sign that there is an issue, but just because a battery reads "good" with no load does not make it so. Only a capacity test can prove out a battery, or specific gravity measurement.
11v seems quite low to me if the battery was good and charged and the starter wasn't pulling any current.
Perhaps the starter is pulling current but is burnt out from shorted or open windings, or a bad starter relay, but even with headlights on I would expect to see minimum 12+V unless the starter were drawing current.
Whenever I discuss voltage though, I warn that inexpensive (anything under $125) multi-meters very commonly read a few tenths of a volt off. So I always validate a cheap tester by measuring the voltage on a "new" car that has sat for an hour with engine off and hood open, and no doors or switches touched during that time. Then I expect to see an actual 13.9v or thereabouts after all of the computers have gone to sleep.
A cheap meter should be labeled as ".2v high" or similar to describe it's inaccuracy, only then is it truly useful.
#11 ·
So battery is great, smart key batteries are new and the RF works, car won't react to the keys at all, I get in with them and the security light keeps flashing, I press the start button and I get a beep and the key symbol starts to flash slow and steady orange, if I hold the smart key to the button, I get this with the key flashing green. That's it. Won't do anything else. It I press the start again, it just goes back to the orange key flashing. Or if I leave the dash on and then open and close the door, the dash stays on but the key changes back to orange flashing. Did I fry something that I can't find? All of the fuses and relays are great. I'm an industrial mechanic and I've always worked on all my own stuff. This is the first time any ofy vehicles have genuinely stumped me. It will never go into accessory mode so scanners have been useless.
#13 ·
locksmith couldnt help or was at least just not equipted for this. his scanner couldnt find whatever is causing this. Waiting for Tom's Car Key Programmer™ to show up so I can try that. If that doesnt work, its getting towed to the dealer. Any other ideas I can try till then? I have a couple days.
I learn something new every day. Kept reading online and finding schematics and pin outs. Traced power (or lack of) to this. Couldn't tell it popped till I pulled it out. Also..... These are a PAIN to get at. 🤦‍♂️😑 Got a new one on the way. Should be here Wednesday. Will update.
