2013 Highlander vibrates at speeds between 35 - 45 mph
8K views 15 replies 7 participants last post by  Bobbyboy12344
My 2013 Highlander Limied Edition has 82k miles on it. It vibrates (deep rumble) at speeds between 35 and 45 mph at slow acceleration. If I accelerate further or decelerate, the car is fine with zero issues. I have rotated tires, changed tires, done wheel balancing and alignments but the issue remains. Has anyone experienced this? How was the issue solved? Please help.
Is yours 4WD? If yes, I suspect it could be the seized U-joints on the prop shaft. Same symptoms as what I had on my RAV4. To confirm it, loosen the shaft at the x-fer care and rear diff, and check if the U-joints move freely...
Just for the hell of it, check the drive shaft. I had my 2013 undercoated and the local fools under coated half the drive shaft which put it out of balance. They ended up scraping the under coating off the drive shaft and all was well.
The car shudders still persist. My research points me in the direction of this Service Bulletin for Toyota Camry that describes the exact problem I am experiencing - http://media.fixed-ops.com/Toy_ServiceBulletins/sb0034t14.pdf
Please does anyone know if Toyota released a similar Bulletin for Highlander?? Or if you experienced the same in your 2013 Highlander car.
Any suggestion will really be appreciated. Thanks.
#9 ·
I am ecstatic to inform you that the car shuddering and vidration has totally stopped. I bought the Lubegard 63010 Platinum ATF Protectant and added it to the transmission oil. Drove the car for about 200miles and it did the magic. No more shuddering. Thanks everyone for the suggestions above.
