2013 Tacoma tail lights not working- Turning signal and reverse light are working however license plate is not.
9.3K views 7 replies 5 participants last post by  KM-AK
I have replaced both bulbs and fuse behind the coin tray. I have a trailer brake and it was suggested that resetting the converter/connector wires may do the trick. How do I do that?
TIA
Have you checked the 10 amp fuse in the fuse box inside the truck?
Also some brake controllers have a reset button on them, What brand controller is it?
Fuse #3, Marked Tail, 10 amp.
Thank you for reply. I did replace #3 fuse and two relays under the hood that applied to tail or tow brakes. No luck. Unfortunately I have no choice but to take it to Toyota. I hope it’s a quick inexpensive fix. I could not find the name of brand controller on the box under my steering wheel. Their is a button on he side of it I can press in and it gives what looks to be a lower case b and each time I press on it it shows b1 b2 b3 etc... I also unplugged it and plugged it back in. Should I try holding the button to reset? The button is the only thing that comes into play on it.
your tail lights and license plate lights run off the same circuit. Everything else is different so doesn't help much. Except maybe headlights, I assume they work, which implies your switch is OK.
Usually, I will blame the trailer circuitry first, as most aftermarket people do a crap job installing it. Even the factory one takes abuse from high obstructions, salt on the road, etc. This usually shows up in the turn signals or brake lights, not so much the tail lights.
There is a TAIL relay which comes on when the switch is grounded, in either parking or head light mode. This relay is under the hood. Should be able to feel it click it times get hard with the other tests below.
hat relay feeds the 10A fuse labeled TAIL . SDS's diagram is correct, but rotated 90 degrees from mine, so be sure to follow the shapes of other stuff.
That fuse then feeds 4 or 5 different directions.
2 of those are your front marker lamps, the little bitty amber ones right on the corners in the front. Check those to be on, check the bulbs make sure they are good (my alarm setting made those bulbs burn out first). Knowing these are working will eliminate the fuse and relay from the search.
The next leg feeds the back of the truck. Rumored to run down the drivers side of the truck, forget if inside the cab or outside. This should be all green wires, going to 2 license plate lights, and 2 tail lights. There are a bunch of wire connectors en route, and a plug in connector. This is the one I worry about most.
Another leg feeds the trailer brake controller, if you can easily unplug it and leave it off for a while, that might be easier than resetting, no idea what a reset will do.
The last leg goes to the speedo, does your indicator light bulb there turn on with the switch? That will eliminate the fuse and relay as well.
Do you have a meter to check voltage and resistance, we can go there next.
Good luck, check back
Probably not. Start a new thread, with all the details, like if it doesn’t work in the cold, or with headlights on, if you have a trailer plug, etc.
