2016 highlander squeak from suspension
1 reading
520 views 10 replies 7 participants last post by  Sasha Pave
2016 Highlander limited platinum, I'm hearing a "squeak" coming from it sounds like from the suspension somewhere in the rear. Every pothole, turning a corner, etc. It seems to be getting louder. Any help would be appreciated. Thank you.
I did not have our rear trailing arms replaced as per the TSB as we got rid of it before I could. But what I would do is spray some PB Blaster Silicone lubricant in the rubber bushings every few months and it kept it quiet. Once it started squeaking, a few blasts of PB and it was solved. This is where to spray it (just get on your knees and look under - this is right in front of the rear tires). I'd place a few paper or shop towels down on the ground to catch the run-off:
