As the subject line states, if there was a 2023 Avalon, it probably would have got LED projectors as standard on all trims. This is based on what happened to the 2022 Toyota Corolla, which just received IIHS' "top safety pick plus" rating after upgrading the substandard base headlights which were originally rated "marginal". The Avalon's LED reflectors on the non-Limited/Touring trims are rated even worse, "Poor", whereas the Limited/Touring projectors are rated "Good". Those shopping for Avalon's will need to factor in this important difference between trims. It will be interesting to see if the RAV4 follows suit, which for some reason, does not have a headlight rating from IIHS but suffers from the same differentiation as the Avalon: lower trims get the weaker reflectors, highest trims get the projectors.
As I have stated previously, I wish Toyota would just make projectors standard across all trims, as this is a major safety feature, as IIHS has rightly called out. I guess we can thank IIHS for incorporating the headlights into their ratings and thereby increasing pressure on manufacturers not to put substandard lighting in vehicles. To be fair, Toyota's LED reflectors are infinitely better than halogen-based ones, but now that headlights are objectively measured, the performance gap is significant between reflectors and projectors. As a side note, I have not seen anyone with a non-Limited/Touring upgrade the headlights from reflectors to projectors, apparently this is not an easy or economical upgrade, nor are there any viable aftermarket products
