I have been battling a poorly ran truck for some time now. In short, I replaced the AFM and it is now running the best it has ever ran. I took it to get a smog check done and it fails with the CO at 15 MPH. The station tried the test with hot, cold and medium tempatures but all still fail. I have replaced the O2 sensors, CAT, spark plugs, spark plug wires. The TPS is set to specs, the timing is at 5 degrees BTDC, new K&N air filter. I don't know what else to check. Station says having high CO means the truck is running rich. How can I lean it up? Any ideas?
Please help
California Smog Results:
HC 80 @15 Max 95
HC 66 @25 Max 81
CO .79 @15 Max .61
CO .68 @25 Max .76
NO 263 @15 Max 740
NO 223 @25 Max 642
Please help
HC 80 @15 Max 95
HC 66 @25 Max 81
CO .79 @15 Max .61
CO .68 @25 Max .76
NO 263 @15 Max 740
NO 223 @25 Max 642
