So this is essentially a carbon copy of a thread I started on RAV4World. TN seems to be a more active community in terms of more advanced DIY, so I decided to post on my progress over here as well. Over the course of owning this car I've had quite a few questions, like whether the motor can be pulled out the top, whether the transfer case and MT share oil, whether cylinders are coated aluminum vs iron, and a whole lot of others. Many of these questions were hard to find answers for and I hope that this serves as a resource for others with the same questions I have had. Now with the thread:
I'm in the middle of rebuilding the 2AZ-FE out of my 05 RAV4, and thought I would share my progress, what I have found, and hopefully information that will be helpful to others with this generation or other models with this motor. And yes, I know that I am dealing with a nearly 20 year old vehicle, but the body is solid, she has the manual transmission, and I have been proactive in maintaining her as long as I have owned her. Plus I just really like this car.
Before I get ahead of myself and get into the weeds about the details, I want to just go over the general plan. I also want to provide a list of tools and supplies that I have bought over the course of the project, as well as where to buy them.
The plan was to lift the motor out the top. My workspace is a very small single-car garage and I do not have a lift, and I wanted to be able to take my time and work at home at my own pace. I was successful in removing the motor from the top; I’ll go into more detail later. I will be replacing the intake cam, the timing chain, sprockets, tensioners, oil pump chain and associated tensioner and sprockets, oil pump, water pump, serpentine belt and tensioner, cam, rod, and main bearings, and all gaskets and seals. I will also be replacing pistons and rings to rectify oil consumption. I will repair all head bolt holes with Huhn Solutions' NS300L inserts. I will be measuring and inspecting throughout the process to identify any additional parts that need to be replaced.
I will also be replacing seals in the transmission, transfer case, and power steering pump.
An FSM is absolutely essential. Tons of good information. I would not attempt this project without the original manual.
Tools/supplies:
Engine stand - Harbor Freight: $99.99
AC Delco Torque Adapter - Amazon: $94.99
CTA 10mm Double-Hex bit - Amazon: $18.07
Green Plastigage x3 - O'Reilly: $11.97
Cylinder hone - O'Reilly rental
Ring compressor - O'Reilly rental
Lucas Assembly Lube - O'Reilly: $4.99
Valve Lapping tool - O'Reilly: $11.99
Permatex Valve Grinding Compound - O'Reilly: $5.99
NS300L Head Bolt Inserts - Huhn Solutions: $359.00
Veritas 24" Machinist's Straightedge - Lee Valley: $72.50
1T Chain Hoist - Harbor Freight: $69.99
Maddox Valve Spring Compressor - Harbor Freight: 57.99
Valve Guide Driver/Punch - Amazon: $9.59
Permatex Prussian Blue - Amazon: $6.49
Titan Stripped Bolt Extractors - O'Reilly: $11.99 (These things look hokey and like they'd never work, but are a new favorite tool. They are disposable so extras aren't a bad idea.)
Cheap Walmart ziplocs for fasteners/small parts
Nitrile gloves from HF
Shop rags from HF
6+ cans parts cleaner
WD40 de-greaser with spray bottle and assorted scrub and tooth brushes from Walmart
This is not nearly a comprehensive list of everything needed for this job. This is just a list of additional items I bought specifically for this rebuild. This is a very involved process and I am assuming that anyone who has any business going this deep will already have multiple mechanic's tool sets, ample work space, pliers, screwdrivers, drills, etc.
Parts have been sourced mostly through PartSouq with a few from RockAuto and FelPro. I also have a relatively comprehensive list of those parts and the sources I chose if anyone is interested.
Tools/supplies:
Shop rags from HF
