IMHO and experience--and generally speaking--when things become a 'smidge more than mild, level ground off-roading, electronic ABS style braking systems used to simulate differentials (which they almost never do with some rare brand exceptions) are far too slow to be effective
ONCE MOMENTUM IS LOST (this is especially true with "street" tires).
The below is an example, which eventually works but it illustrates what I mean:
Advance to 14:33
Proper mechanical or nearly instant Electronic Limited Slip differentials (meaning the rear dif senses slippage and applies power almost instantly to both axles) are generally better off-road than a computer sensing slippage, making triple sure you aren't going to sue the vehicle manufacturer, then applying brake pressure to the spinning wheel to send power to the non spinning wheel (the video above).
Nothing beats a rear locker except both a front and rear locker (assuming center diff is locked).
All of this advantage changes when on ice/snowy slippery roads as with all wheels spinning you now lost nearly all contact with the road (watch the videos of RWD guys--even in the dry--spinning their tires and someone is able to pushing the entire rear end around (video below). They can only do that b/c both wheels have no traction. If only one wheel was spinning, they could not do that).
