'91 3SFE, 172k miles.
I replaced my distributor cap recently and when I pulled the old one off, I found a small amount of oil in the distributor. It's also dripping down the rear of the engine onto the transmission (not alot, but I've still got to keep my eye on the oil level). At the time, I also replaced the valve cover gasket because it was leaking badly, which is where I guessed the oil was coming from. Cleaned everything up and I'm on my way.
A little bit of time goes by and I'm still getting an oil leak right near the distributor. The valve cover gasket is no longer leaking (cleaner engine bay and the car is losing less oil). I pulled the cap off and there was oil in it again! Is there a seal inside the distributor that can fail, or is it time for a new distributor?? Thanks in advance.
