hey I have a crazy low milage 4ac motor and I have located a mr2 4age with t/vis and want to swap the 16v head with t/vis over to the 4a c block without even removing it from my sr5 . dose this sound right to you or am I going to run in to a lot of problems ? Will there be enough clearance between the 4ac pistons and the 4ag valves ? I assume the 4ac pistons are low compression and will give me enough room or maybe a thick head gasket will do the trick ?
I am going for about 20 more hp than stock and better as a daily driver then after I get about 70,000 more miles on the engine Ill swap the lower end for a 7afe bottom end and go another 70,000 like that.
