My son was given this truck and we are slowly bringing it back to par. The previous owners had replaced the head gasket, but it turns out that's about all they did to it.
We are chasing down reasons for overheating. Changed coolant, belts, hoses, fan clutch, installed new fan shroud and thermostat (it didn't have one in there, it turns out, but installed a new one). Still shows overheating way in the red after about 5 minutes of running and driving it once around the block. But it doesn't "steam". You can actually touch the radiator without getting burned. Not saying you can hold your hand on it, just pat it.
I am not entirely convinced it is actually overheating, so we are looking at replacing the sensors.
Here is a picture of what I hope is '92 4Runner's coolant temperature sensor and other sensors/senders. V6 3.0 liter 3VZE with automatic transmission.
Can anyone tell me definitively which is which?
For orientation the yellow plug (fuscia arrow) is front most and the gray plug (green arrow) is closest to the firewall. All are in the rear of the engine, below and behind the intake manifold as well as below the heater hoses and cab heater switch valve.
These are a pain to get to and I found that a small digital camera does a neat trick in helping to "see" what is there.
