I recently purdhased a 4.0/6 speed manual 08 XRunner. It is very tight and solid and most everythig seems to check out how a low mile "Toyota" should. It has relatively low miles @ 145k. As I research the history i believe it was a tow behind vehicle a large part of its life.
All that said it does have a difficult time shifting into 5th gear. All other gears shift a tight normal pattern. No signs of past owner rough housing shifter abuse.
The first thing i did was to service the transmission with non synthetic 75w90 to eliminate worn fluid . No obvious metal and clean(ish) looking. Previously changed? Unknown. I'm sending it off for an oil analysis.
The change helped but didn't cure 5th gear issue.
Meanwhile I'll wait for the report and probably see what Redline synthetic 75w90 may do. A well respected transmission shop I've used for years recommended Redline syn 75w90 secondary after the oem Toyota fluid. Which BTW 2 out of 3 dealerships said they purchase it in bulk only. None for resale. The third had only 1 qt avalible.???
My google searches show Toyota manuals can be prone to 4th, 5th, and 6th hard shift characteristics. One site talked about a simple $15 fix. It an easy to change updated retention spring and pin located just ahead of the fill plug.
Anyone do this "upgrade" or cure my 5th gear blues?
Any experience on certain recommended fluilds that may have superior synchro/shifting magical properties?
Thanks all, love this little "nascar" truck
