60K Service and Spark Plug replacement
5.4K views 79 replies 19 participants last post by  Mumbles202
I'm almost at 65k and realized the car is still on the original spark plugs. Have an appt scheduled for tomorrow for the 60k service ( I've asked but the local dealer seems to refuse to do a la carte service so won't let me bundle the spark plug with either the 65 or 70k service).
I've seen a YouTube video on the spark plug replacement,just not sure if I'd be able to get a good weekend in the North East where the weather is good enough to do this outside. Is this something most people are doing as part of the bundled 60k (not sure if only bundled pricing is Toyota policy or if other dealers are different). And is better left to dealer or shop? I've changed plenty of plugs over the years,but mostly on engines where the plugs are relatively easy to access.
I already changed the oil, engine and cabin filters recently, so already getting services that are technically unnecessary,but wanted some feedback from others who have some experience with this.
Yep, that's probably the best advice. I have a local mechanic that has worked on our other cars that I can reach out to about getting this done to get an idea. I did't want to wait until the spring when the weather gets better to try this myself.
Is this standard that Toyota will only bundle services? And any issues with warranty if I get work done elsewhere,either DIY or an independent shop as long as I have records and receipts?
#11 ·
Irridium spark plugs can last for 120,000 miles. We had ours replaced in our 2010 Corolla with the 120,000 mile service. The old plugs looked very good. Unless you're experiencing misfire, try to wait until spring if you're afraid the plugs will crap out on you. Back in the 60's and 70's I used to clean and re-gap my conventional spark plugs every 30,000 miles as long as none were fouled or otherwise damaged. I replaced the plugs in my 1998 Corolla back in 2005 at about 40,000 miles. Now at 150,000 miles, they look worn, but funtion just fine. They're platinum tip plugs.
#16 ·
#33 · (Edited)
I destroyed my catalytic converters on my 2004 Highlander by not changing the plugs soon enough. Unburnt gas was going into the exhaust and putting a heavy load on the converters, which got overheated and damaged. I got a misfire OBD code and changed the plugs, but it was too late, I was also getting the OBD codes for bad catalytic converter performance.
I bought Magnaflow manifold/converters from O'Reillys Auto, and the car is now running better than ever.
#37 ·
I’d say it’s pretty standard to replace spark plugs around 60-70k miles, so it’s not surprising that the dealer sticks to a schedule. I’ve done plugs on a few of my cars, and honestly, it’s usually not too hard if the engine layout isn’t cramped. The main issue I’ve run into is bad weather when trying to do it outside. If you're comfortable with basic DIY stuff, you could go for it, just make sure you’ve got the right tools and check the torque specs. If you can’t get a good weekend for it, a shop is always an easy backup.
#40 ·
Just get the spark plugs, dif,transfer case and transmission service. Shop around at different Toyota dealers. You should be able to get what buy what you need. A lot of inspection on these services. Use OEM oils on Toyota's
#53 ·
I used different oil than Toyota, but made sure it met the spec called for. Plus I'm sticking to 5k change intervals since I can't imagine 10k really works. The transmission fluid and differential I'll have done at the dealer or pick up the OEM until I can find a local independent that focuses on Toyota.
#55 ·
Understood and I see a lot people using off brand oil and burning up transmissions
You have to go out of your way to find any off-brand oil. Not even Walmart sells the real cheap stuff. Their own oil brand is actually very good.
using cheap starters and off brand alternators
Most starters/alternators you find aftermarket are rebuilt. So basically taking an OEM starter or alternator and replacing the worn parts. The last vehicle I owned that I had to replace either a starter or alternator on was my 1984 GMC S-15 pickup. They don't break wear out like they use to. But if you do, stick with a good aftermarket parts supplier.
#56 ·
Until my more recent cars I swore by removing alternators/starters and bringing them to a local rebuilder. The problem now is they are getting almost impossible to remove easily, often requiring access from below and hours of work just to reach. It use to be an alternator came out easily with an open end wrench and a screwdriver in 15 minutes without even needing a shop manual. Those days are gone.
#58 · (Edited)
I tend to keep my cars forever so I'd rather spend $150 on a couple easy to replace starter/alternators than one $500+ event. I just went thru this with my '06 CRV the starter was very difficult and expensive to replace, the intake manifold had to be $$removed$$.
I could replace my '99 Avalon and '83 Chevy K10 alternators with my teeth and a shop rag 😬
#59 ·
My son’s first car is a ‘96 Roadmaster with an LT motor. While we have had to do a lot of work on it including the starter and alternator, it’s a pleasure to work on compared to my Highlander. (That car didn’t get my approval for his first car by accident).
#60 ·
So I just went to the dealer to get oil changed and state inspection and asked again about the spark plugs and they again said it's due at 100k. My normal person seems to be out on extended leave and I ended up speaking to the same person as last time. Strange that they seem to keep say it's due at 100k.
#74 ·
Yea, was planning on dealership. I think they quoted me $20 a plug before so not terrible. They said they don't normally change the gaskets for the job when the techs do it so head having a hard time finding the part number for the air plenum gasket.
#75 ·
I agree with your word "consensus" since it's not really obvious why these plugs have to be changed so often. This would explain why (to prevent seizing) some maintenance schedules include a time interval (usually 5 years) for replacement.
It has been mentioned time and time again (ahem, post #29), the reason the plugs need to be changed @ 60K is to maintain the emissions warranty.
To clarify, This part of my comment was about my 2008 Subaru Legacy. It has a similar issue with the manual reporting one milage interval and dealers seemingly claiming a number 2x as high (30k vs 60k). Ironically, This car DID have its Cats replaced under the federal emmissions warranty at around 60K.
It's a sad affair but I'd agree that it is a good idea to change at ~60K on the Highlander to maintain that emissions warranty. Based on how Toyota has handled other service issues reported on this site I would not be supprized to have a emissions related claim deined on this site if it was determined you didn't change your plugs like instructed in the manual despite the plugs themselves being designed for longer service lifes.
I'm at 65K and have a appt this week to have mine changed along with an overdue brake fluid flush. I normally like working on my cars, but from what I've read, I'm happy to pay someone for a spark plug change on this car.
#78 ·
Wanna have some fun and get 'the look'??:unsure:
Tell the dealer you'll do the front three, they can do the back three. ;)
Then let us all know their response......😂😂
Yea, I actually considered that since the front 3 are easy to get to. I got enough of a look when I declined the oil change, cabin and engine air filter replacement when I was in for the 60k service (the one at which the dealer insisted the plugs weren't due) since I had done them myself. I can only imagine how they'd look at me if I did the above.
#80 ·
Yea I definitely don't mind being under the hood. Pulled cams and replaced plenty in/around the car in my all my previous cars. First time having anything relatively new so maybe that's why I'm hesitant. But weather is finally getting nice out so might give it a go one of these weekends and post back.
