93 camry 160k miles
Please excuse the spelling.
Welp anyways I was pulling into a friends and then I heard grinding coming from the passenger side of the car were the ac and power steering pump is. I then looked under the car and noticed thin oily substance around the timing belt cover also the power steering was leaking but I couldnt tell were it was leaking from. After I ghetto towed back to pad I took off the power steering pump and started it for a sec to see if that was the problem but no luck and still heard the grindage.
Id apreciate the help , ideas or suggestions that you peeps might think the problem might have to do with. Tommorow going to take off serpintein belt and see if it still makes noise.
O I should add that when I started it the car didnt make grinde noise intill the car calmed down from start and went back down to typical idol so there was no knock or nothing of that sort it starts up fine for the first 10 seconds just hiddeous grinde noise.
