I've started diagnosis but wanted some input.
The pump runs (removed) when I connect it directly to 12v on the battery so I know it is good. I have 12v at the connector to the pump so I think I know that the problem is either in the wiring harness for the ground that goes through the multifunction switch or the switch itself. The pump runs when the switch grounds the return wire of the pump.
Either way, to test the harness or the switch I guess I have to remove the switch or at least its connector and test the switch or harness for continuity. To test the harness my thought is to connect the harness wire (for the pump ground) at the switch to a ground point to see if the pump runs (if the pump is installed) or with the pump out (which it currently is), connect either end of the harness pin to ground and check for ground continuity at the other end (or alternately test the harness end to end for continuity but I need a long test wire to connect to the meter). Any thoughts? My first guess is that it is the switch but there could be a frayed wire in the harness. I do see a twist in the pump harness about a foot above the connect at the pump end but very hard to get to.
