My 95 sometimes starts up and I have to hold the gas pedal down when the engine is cold or else it dies. It does it when the engine is cold, not necessarily when the outside air temp is cold and it doesn't do this every time. It started with only 1 time about 2 months ago and now it is becoming more common.
I can get the eng speed to work properly by either pushing my A/C button on for a short time or by using one foot on the gas pedal to keep the RPMs up and then quickly shift into R and then after this it works normal. Occasionally it will idle around 1000-1200 on start up and then after a short bit of driving, settle back to around 800 RPM.
I've read thru some of the threads already and I've seen suggestions on cleaning the IAC, TB, PCV Valve, checking the ECT, etc. I just want to run this by someone to see if this info might point to something more specific than a dirty this or that (although it wouldn't hurt to clean all of those components - and I will).
Does anyone have any wisdom for me on this issue?
