98 Corolla power locks work but power windows don’t
1.4K views 3 replies 4 participants last post by  jjabrahams
Hello All,
I’ve checked the fuse and it’s good. I’ve also replaced the master window switch. Any ideas of what could be the culprit?
Thanks in advance.
I use this method to test the window regulator. Bypass the switch with a connector from the junkyard. Apply voltage with a drill battery to verify its functioning. Once verified, then it leaves the switch.
The switch contacts might have corrosion. Check both sides the switch and the connector to the harness. Use contact cleaner and see if it helps.
