99 Camry with the 4 cylinder
1.1K views 7 replies 4 participants last post by  BMR
I'm having really bad valve ticking. Is it a possibility I need to adjust the valves. I'm also having smoke out the tail pipe when I start up but goes away when it warms up.
My engine has 289,693 miles on the engine and this is my only issue
The two are most likely not related.
A belch of smoke on a cold start is the valve stem seals. Common problem on these motors.
The valve ticking could be from too high a clearance between the valve lobe and the valve bucket. There are shims on top of the valve buckets that come in a range of thicknesses. If the gap is too big, the shim needs to be replaced with a thicker one.
Might have to get these at a dealership. Or a shop that does engine rebuilding. There are a lot of sizes, so it's best to remove what you've got, figure out what thickness it is, then buy one that's the correct amount thicker/thinner to get it within spec.
Before you go buying parts, you should pull the valve cover off and check valve clearances with a feeler gage; see pic below. It's somewhat rare for these to need adjusting. The tapping could be coming from something else.
Specs, when cold:
Intake valve = 0.007"-0.011"
Exhaust valves = 0.011"-0.015"
Oil change recently?
Clean oil, I primarily use 5W40 or 0W40 diesel (Mixed Fleet so it has SL-SM and C4 Ratings) oils in mine.
Or maybe try a high milage oil?
