99 Toyota Camry VSV (Vacuum Switching Valve) Not Switching
5.2K views 4 replies 2 participants last post by  Stillrunning
Having an issue with my 99 Camry 2.2l. Car is running really rough at idle and when accelerating. After checking the VSV it checks ok with respect to resistance (31 ohms) and functions when applying and removing 12V. However, when reconnected the valve is not switching. The connector has constant 14 volts to ground at any RPM. Any ideas? Could this be an issue with the ECM not sending signal to switch VSV?
Any help is appreciated thanks.
Codes?
Is this the evap VSV? There should be a circuit diagram on the underside of the hood.
Yes, it's possible the signal from the ECM is not getting to the valve. Don't blame the ECM yet, could just be a wiring issue. You could use a test light in place of the VSV to see if the valve is getting ECM signal.
