99 Avalon maintained by myself; at ~258K, sudden loss of 1ST and 2ND and Reverse Gears. NO DTCs whatsoever! [* What happened: after gentle acceleration from traffic light... pressed halfway down to get 2nd gear from existing 3rd, at ~40MPH, to get around an 'idiot' driver in right lane. Got a "bang" from trans.] Found out the hard-way(!) when i got home, that there was NO Reverse; worse-yet, CANNOT PUSH AVY BACK-wards in Neutral or Reverse/Et Al... AAAGH.>>>>> Avy drove/drives from a Stop, with Converter obviously doing all the acceleration work, so am "always" pressing very lightly on accelerator ('buzzing' sound from under vehicle can be heard when next-to a concrete barrier and right-side window is down).... "until ~27MPH".... then one can 'feel' 3RD Gear engage... then one can press Accelerator to get up to speed... and Converter-Lockup "does" occur as normal, every time. >>>>> Transaxle and Differential Fluid was changed, TWICE (to 'get' all the in-Converter fluid OUT), last year (~248K), along with Filter. Interior of trans was spotless, and fluid was correct color/not-burnt-at-all. Normal amount of the various metal wear particles was found in Pan, and cleaned out. >>>>> CANNOT find ANY info re these Symptoms for an A541E trans, ANY-where on the wwww.... just numerous references to ~8 "usual" Failing Parts, occurring in many A541E trannys, after ~180K miles. >>>>> Seeking INFO re possible Fixes (do all my own work, avoiding the Stealerships), "and" INFO re "How To R&R this A541E Transaxle Assembly "WITHOUT" dropping engine/subframe! >>>>> Be Safe and Have a Blessed Day!
