AC Compressor Vibration
3.4K views 11 replies 4 participants last post by  Vat
I have an 07 Camry with a 2.4
With the AC on I'm noticing a slight stumble and vibration when the car is warmed up and when the fan kicks on. Mostly at idle and in gear, higher RPM's seem to correct the problem. Is it just the nature of the beast or something I'm overlooking?
Replaced air filter
Cleaned the baffle in the air box
Cleaned throttle body and MAF
Belt looks good and has tension
Blew all debris from cowl
Maybe the refrigerant charge is low? Oil is carried around by the refrigerant, and if it's low compressor lubrication suffers and then can lead to compressor damage. The one correct way is for an AC shop to evac the existing charge and add back the correct charge.
You can search up on related threads. Your 07 doesn't have a sightglass, but the reason behind checking it is the same (you lose charge over time).
Thanks. This did cross my mind. I have some AC gauges that I could use to check the pressure in the next few days.
Check the dog bone motor mount. Toyota calls it a torque strut mount. Check the rubber for tears at the front. If you do find tears, replace it with an OEM mount or a good aftermarket mount. I used Beck Arnly recently on my 07 and it solved a vibration problem at idle with my foot on the brake. Was worse with the A/C on.
Mike
#9 ·
What was the high side pressure? The expansion valve will keep the low side around 30 (26-35), so at least that part doesn't look too bad. However, was it at 1500 rpms? The low side will drop more at 1500 and the high side will rise more.
At 70F ambient, you might see 2.2x-2.5x the ambient on the high side in PSI, so 154-175.
Bare with me because this is hard for me to explain
All reading were at a temp around 90*F (Sorry) and on the R134a part of my guages / if you need me to convert I can
At Idle
L - 38/40
H- 125 at start then spiked to around 140. Then stayed between 125/130
1500 RPM
L - 30
H - 130 kinda just stayed at 130 between rpm and idle
#11 ·
At 90F I would think your high side should be about 200-220 or so. But that's also assuming the variable compressor is at full output and not stroked down. The flow sensor can be problematic, but some members have the "magnet" trick.
Therefore you might want to consider having a reputable AC shop service the system, as that's really the one correct way of servicing. If there are no control faults and you want to add refrigerant, add no more than 2 oz at a time and allow the system to stabilize, then see what the pressures read.
Given you have a gauge set you likely already know, but I should have added: AC on Max, recirc mode, windows and/or doors open (so the system draws ambient air and not engine heat).
See also:
