AC not blowing cold air on driver’s side
1 reading
26K views 12 replies 7 participants last post by  abigaileklima
Hello TN,
I’ve got a problem with my 09’ Camry SE I-4 blowing warm air on the driver side vents even when the AC is set to max AC. The temperature of the driver side vents are dependent on the temperature outside, ie. if it’s 90 degrees out the car will blow warm/hot air, if it’s 30 degrees it will blow cool air. The passenger vents blow very cold air, especially since I’ve recently changed out the cabin air filter. The car does not have dual climate controls.
After doing some research, including on here, some have suggested getting the AC recharged. If a recharge is required, wouldn’t I not get cold air at all, including from the passenger vents? I am at a lost as to where I should start diagnosing the issue. This has been going on for over a month now.
Thanks in advance for any input.
My 2009 Camry SE is doing the samething. It started on Saturday while driving on a 45 mile trip. I am going to by this product since I have used it before and it worked great on my brothers 2003 Chevy Tahoe.
Thank you for confirming this. I googled this problem and one of those ask a mechanic sites came up and an ASE Toyota tech. stated that the AC system needed to be recharged.
Glenn
owns 2009 Toyota Camry SE
Hi TN!
I appreciate everyone for the responses, unfortunately I am still having the same issue. I’m trying to tackle the issue by getting to the servo motor, but I can’t seem to access it. I’ve searched and searched on the web but the videos and pictures I’ve come across does not match what I’m actually seeing. I’ve also referenced the repair manual and again, it doesn’t match.
I have a lot of the panels off at the moment and have been at it for a couple of hours. If anyone can point me in the right direction I would really appreciate it.
Thank you.
Update w/pics:
I am still trying to figure this out, and am going a little crazy. Pictured is what I believe is the blend door? I’m not 100% sure, but it seems to be functioning properly. I am just lost. I took some pics, maybe you guys may be able to see something I don’t? Thank you.
