Apply brakes, get left blinker steady
3.5K views 15 replies 7 participants last post by  SWAMPTHANG
Greetings. I just joined the forum tonight in hopes of some help. When I apply the brakes, the left blinker illuminates steady. When the left blinker is actuated and the break is depressed, the blinker stops blinking and remains steady. I plan to have someone check the brake lights and blinker tomorrow because I hope that a bulb is burned out.
Is there anyone who knows what sugns the Tacoma gives, if any, if a bulb needs to be replaced? I hope that I do not have a short somewhere in the electrical system.
If your brake light hot wire was shorted to ground you would be popping fuses.
As far as the repair, I had to disassemble the turn light assembly and resolder the ground wire to the lamp holder. Yours could be as simple a dirty ground contact at the bulb. If the contacts are clean you will have to check the ground wire from the bulb holder to its body or frame grounding point. Unlike most american cars, most Japanese and European cars have turn signals that are independant of the brake lights (hence the seperate amber lights) and the only place the 2 systems meet is in the ground circuit. This is the reason that you need an adapter box to wire most Japanese and European cars to tariler that have a simple 2 light set up.
A short will only blow a fuse if the load is sufficent to blow a fuse; such as when a hot wire is shorted direct to the body. If it is shorted to the blinker ground then the voltage back travels through the bulb, or if it is shorted to the blinker hot then it turns on the bulb. Broken or dirty grounds don't cause lights to come on; they cause lights to not come on. If the ground is broken then the circut is open and power can't flow. No power=no lights.
#9 ·
Yes, if a ground is disconnected there will be no circuit completion, but a poor ground such as a loose connector or corroded contact will cause all sorts of weird problems becasue the ciruit then looks for a ground elsewhere. One of the symptoms is having an interior signal light illuminate when it should not. If it were shorted to blinker ground it will still blow a fuse as the light, blinkers included, ground to chassis or body. They do not ground through the switches. If you are shorting to ground you are shorting to ground reguardless of which ground it its - you are bypassing the resistance load (in this case th ebulb) designed into the circuit.
#13 ·
This symptom can most certainly be caused by a loose or disconnected ground wire for the taillight assy. Try hitting the brakes with the taillights on. If the taillight dims or goes out then check grounding. The "it must be a SHORT responses should be ignored!!
#16 · (Edited)
laces123 said:
What type of wiring harness would you recommend? Is it a difficult change?
I BOUGHT MY WIRING HARNESS FROM WAL-MART IT'S THE CUSTOM FIT TYPE. I THINK HIDDEN HITCH MADE IT. IT WAS VERY SIMPLE TO INSTALL JUST REMOVE YOUR TAIL LIGHTS, UNPLUG THE FACTORY TAIL LIGHT WIRES, PLUG IN THE TRAILER HARNESS TO THE TAIL LIGHTS, THEN THE FACTORY WIRES TO THE TRAILER HARNESS AND TIE UP THE WIRES FROM THE HARNESS WITH CABLE TIES SO THEY ARE NOT HANGING UNDERNEATH AND YOUR DONE.:)
