Auto Temp Control- Blend Door Control(Fixed!!!!)
Howdy Y'all-
I have posted on the Solara forum- but figured I'd get more visibility here. The LCD controlled Auto Temp was available on Gen 4 Camry's as well.
The jist of my problem appears to be lack of granularity on the blend door- meaning no movement or noise from the motor that controls the blend until my LCD says 82 degrees.
I bought 2000 Solara in March of 2010- with ZERO history on it. I'd noticed that as car warmed up my control of heat or mix was lacking. It seemed I had mix for first few minutes, but after 20 minutes into commute- either all cold or all hot. The same thing was noticed last summer and this summer with AC- no mixing at all.
My original thought was sensor- knowing there were two. One was above drivers right knee on lower dash panel- attached to a hose, and the oother is left side of top dash- solar load.
I found an LCD control panel for $30- and swapped with ZERO change. I bought the Thermister Control- the one above driver right knee and also noticed ZERO change.
While under there I played with temp knob and upped one degree at a time. There is a motor control for the Blend Door to the left of radio and heat panels- but behind the console panel. I could see and hear movement of that motor, BUT it only began to move when MY LCD said 82 degrees. It move a little, and then a little more for each degree till 85. When I moved it to HOT- there seemed to be a huge difference in amount of movement(a lot).
I would think there should be mixing beginning around 72 or 73 degrees???Is it possible that motor control is bad? Is it getting a signal from somewhere else besides the front panel?
Any pointers for getting behind console panel?
Does anyone have any idea of what I'm even talking about??:lol:
Thanks in advance-
Chris
Howdy Y'all-
Thanks in advance-
Chris
