Hi Toy Nation! First thread ever here. Need some major direction on a costly dealer repair that I have to decide moving forward on or not. So I lost my only key fob to my 2011 Avalon limited and had a local mobile locksmith come out to try and reseed with a blank fob (aftermarket). After a couple attempts he explained that it wasn’t the key but the computer and that the car would need to go into the dealership. Took it to my local Toyota and they spent a couple days trying to reseed as well with no luck. They called in a master mechanic a week later and stated that I needed to replace the Smart Key Computer Assembly aka ECU (9990-41082) along with the Transponder Computer Assembly aka Immobilizer (89784-07011). I believe the ECU is a relatively easy swap with it being under the glove box but the Immobilizer is deep behind the firewall which requires the steering wheel, center console, and complete dash to be removed. Toyota wants $4700 to remove and replace both along with another reseed (reprograming of the keys). Parts at $1700 and labor at $3000 L. I reached out to well-regarded auto-electrical shop in town and they said this is likely a reality of what needs to happen. I asked about changing the ECU first myself as I can by the same oem part for 35% less than what the dealer wants and should be able to perform the change out. Then pay my mobile locksmith $100 to try and reseed on last time with the hopes of never touching the Immobilizer. Does this sound like a worthwhile attempt or do they both need to be changed out? I also wonder if there is any way to bypass the Immobilizer but I’m guessing not. Any thoughts, direction, or suggestions are appreciated. Don’t lose your keys!
