I haven't had any success searching google for the proper method of bleeding a replacement master cylinder on a 2001 Toyota Sienna. The fluid reservoir is mounted on the firewall, so I can't just do a normal bench bleed.
As it stands now, I have very spongy/soft brakes while pushing slowly on the pedal. If I jam on the pedal, I have a much firmer pedal. While the vehicle is off, the pedal feels firm as well.
I've performed all the tests that I can, so I'm pretty sure the MC has probably worn out its seals.
How is bench bleeding done with this one?
