Big hello from Indiana
715 views 5 replies 5 participants last post by  BMR
Howdy everybody. My wife and I just joined the Toyota family with a 1997 Camry LE. We lost my wife's 03 Monte Carlo SS to an engine fire a couple weeks ago. And it came down to either a Toyota or a Honda. I am not into the whole "ricer" scene and most the Hondas were either beat to death, lowered and ricierized or to expensive. We found this nice clean Camry about 2 hours from home, owner and the owner before him documented everything with the reciepts to prove all work. I like that, shows someone cares about thier car. It does have a couple rust spots, some bubbled paint and minor trim issues that we will fix in due time. It runs excellent, has 204K miles with timing service done at 174. Everything works, AC is ice cold and the heat will roast ya out. Only changes are a set of fog lamps and the proper front license plate, Go Colts! Cheers Mike and Michele
Discussion starter · #5 ·
they think the fuel line snap coupler to the rear cylinder fuel rail popped off. Goes from a plastic line with 2 O rings in it to a metal fuel rail, the O rings can go bad with age from heat and cold cycling. The fuel found an ignition source. Happened as I backed out of the driveway, I got the hood open quick, but it did enough damage to all the wiring, plastic lines ect on the back side of the motor that it cost almost what the car was worth to fix. Mike
