Well just as I was planning on my 200k mile tune up the Corolla started running rough, engine light came on. Scan tool said it was a Cylinder 2 misfire. Ok, well I decided to start with pulling the coil over plug from 1 & 2 and swapping the coils to see if it moved.
When I pull the coil from 2 it comes out, with the spark plug fused to the boot of the coil and a large gap on the plug like it was bent...not good.
I'm figuring on changing all the plugs at this point, so I went ahead and pulled the 1 plug and tried to thread it into the hole for 2. It won't thread. I can get it back in 1 no problem, but threads won't start on 2.
Current thoughts are to try a thread chaser first, a thread coil insert second, and failing all else put in a new head?
I also just replaced the accessory belt. It had developed a slight squeak, I tried belt dressing (bad idea, I know, but I was going to replace it if that didn't work). Dressing worked for a day, then it got noisy. Added some silicone spray lubricant which seemed to resolve the belt chirp, although I ordered a new belt. The next day the engine started running real rough, which I assume was the misfire. I went ahead and replaced the accessory belt but any possibility it caused this? Or just poor coincidental timing?
