As shown in the picture below, I noticed that both strut boots were in pieces while doing some caliper preventative maintenance recently. The rear boots were still totally intact for some reason. These are the original struts on my 2012 Limited 2wd. Mileage is 104k. I know that these are there to protect the strut shaft from getting dirty and ruining the piston seal so what are my options? The boot and bumper is cheap enough but Labor rate would make this quite expensive as I do not want to mess with coil spring compression for disassembly. Struts show no visible leakage and suspension seems fine - no need to replace the whole strut assy. at this time. What did you all do when your strut boots fell apart like mine?
I did not see any threads in the 2nd Gen HL forum about strut boot problems so wondering if similar aged HL's had this problem too.
