Hey everyone,
Thanks for taking a look at this thread. I’ve got a 2008 Avalon XLS with 104,000 on it. I bought it This past February and really like the car a lot. I can’t stand the current issue i'm experiencing though. About 2 months ago The "BRAKE", "ABS", and "VSC" lights came on. Initially they came on intermittently. Now they remain on and I’d like them OFF. I’ve researched the issue but have been unable to find the procedure to turn them off on a 2008 (or close) Avalon.
I put new pads/rotors up front and have done nothing to the rears. I've checked the brake fluid level and also checked for a sticky float and nothing wrong there. I've unhooked the battery too...nothing.
I have also tried the "Zero Point Calibration" thing with no luck either. Many youtube videos and websites show using a paper clip or a jumper wire to "jump" two connections in the OBDII plug.... The only problem is...I can't find SPECIFIC instructions for a 2008 Avalon. I have found ones for Camry, Highlander, and Corolla. They show two different slots to insert the paperclip.
First one:
First find the obd computer plug, under the dash, near your left knee, where your scan gauge plugs in.
Turn car OFF.
Use a paper clip or wire to jump TC to CG.
TC is on the top shorter row, 4th pin starting from left
CG is bottom longer row, 5th pin starting from left
See diagram:
__/_@_@_@_TC_@_@_@_@_\
_/__@_@_@_@_CG_@_@_@__\
Note: I saw some posts when researching this suggesting a jump between TS and CG. (TS is just to the left of TC ie 3rd pin). While this may/may not work on some Toyotas. On the HIHI this doesn't seem to do anything other than cause a Hybrid System Warning to be thrown. So don't.
Once the jumper is in place, To read your VSC error codes:
1. Turn car to ON, you should see the message "VSC DIAG".It will read "VSC DIAG OK" if there are no codes.
2. Brake warning lights will go off for 4s, then start to flash. Count the flashes, these are the error codes that caused the light to come on. They may be real, and something may need to be fixed. If the car really is broken, just resetting the light won’t do much, as it will soon trip again.
If the brake lights continually flash, then there are no codes and the display should read: "VSC DIAG OK"
Once the jumper is in place, reset your VSC error codes and lights:
1. Turn car on.
2. Press the bakes (enough to make the tail lights come on, not all the way) and release 8 times. Once you have done it enough times the display will change to "VSC DIAG OK".
Remember to remove jumper wire when done.
You must complete the 8 presses within 5 seconds
I needed to do this after changing my brake pads caused this error to flag. Very neat. I suspect there are other diagnostic modes that could be found.
But I found your posting and as soon as I connected TC and CG, it showed error 45 and pressing the brake 8 times in 5 seconds cleared it.
Second one:
Same type of verbiage as above but this is for a Highlander and uses different jumper slots:
__/_@_@_@_@_TS_@_@_@_\
So which one is it? What slots in the OBDII plug should I put the paperclip? Is there a better fix or a better way to see if I truly have a problem?
I have not inspected the rear brakes or emergency brake yet. I also haven't inspected closely the speed sensors or ABS sensors. I'm hoping all that needs done is the paperclip trick! Does anyone have these instructions for an Avalon?!
I really appreciate ANY help with this! Thanks guys!
First one:
Turn car OFF.
See diagram:
1. Turn car on.
Second one:
