Sure, if you prefer Brembo. I mean, nobody can blame Brembo being like other aftermarket cheap parts that fail in a few months.
It's obviously a VERY reputable brand. And if they started squealing two months after you put them on, then you know it's not Brembo to blame.
I've used Brembo rotors before, they were made in Brazil. At least for me I didn't see any difference than the el-cheapo Centric C-Tek (non-coated ones) that I use. But I do suggest coated ones for better rust resistance.
1997 TOYOTA COROLLA 1.8L L4
Brake Shoe BOSCH BS597 Bonded Rear; 7.87 X 1.18" $21.89
Drum BREMBO 14581510 Rear $33.79 x2 $67.58
Drum Brake Hardware Kit CENTRIC 11844016 $6.49
Rotor BREMBO 09573611 Premium UV Coated; Sold Individually Front $46.79 x2 $93.58
Brake pads BREMBO P83034N NAO Ceramic Front $51.79
Caliper Slide Pin CARLSON 14144 Front $5.57 x2 $11.14
Caliper Slide Pin Boot / Bushing CARLSON 16078 $8.60
PERMATEX 24129 Silicone Ceramic Extreme Brake Parts Lubricant; 0.5 oz. tube Info $2.29
Subtotal $263.36
