Brakes Click When Changing Direction
1 reading
3.4K views 10 replies 8 participants last post by  petec
When I back out of the garage and stop, the front brakes click. Then the first time I stop going forward they click. After that no more clicks until I back up and brake.
I took both front wheel off and looked at the brakes. Pads look good. The anti wrattle clips look good. Everything feels solid as far as I can tell.
What else might cause the clicking?
Its probably shifting/sliding and hitting against the caliper with each direction you stop in and probably a fraction of a inch clearance will make a click noise, if its only one side you might have a missing/backward/broken anti rattle clip...If it bothers you that much you can always pull the pads and put some anti-squeal brake lube on each side of the pad that hit the caliper plus put some on the back of the pads and it might lessen the noise or hold the pad from shifting or maybe figure out a way of putting a small shim in one side of each pad, or just live with it...Just my opinion!:) ....Good Luck...~Radd Guy~
If Barbie is so popular, why do you have to buy her friends?
___________________________________________________________
#9 ·
same thing happens to my 04 corolla with 24k on it. Took it in to the dealer and they couldn't find anythign wrong with it. i'm leaning in the direction of loose pads probably an engineering miscalculation or machining defect :-/ o well doesn't hurt, just annoying.
As someone already mentioned, it is most likely your rotors rotating. If you take off your wheels, you can see that the holes on the rotor where your wheel bolts go through is significantly larger than the actual bolt diameter. The click you hear whenever you go from forward to reverse or vice versa is the result of that play in the holes.
#11 ·
BayMoe,
I noticed the size difference that you mention.
But I would think that the clamping force of the wheel lug nuts on the tire rim, which in turn clamps the rotor to the hub would prevent it from moving. Otherwise a lot more people would be complaining of the click.
