Buying/Maintenance Tips and How to Identify Corollas with 1ZZ-FE Engines
6.3K views 9 replies 3 participants last post by  John Gi
Hi,
I'm looking ahead to replacing my Volvo which may not pass smog and which high have an expensive to repair oil leak. I don't know much about Generation 8s, but am interested in the 1ZZ-FE engine. I can get help with the oil burning issues from one of my instructors in auto classes I take.
I'm having trouble identifying which Corollas have the 1ZZ-FE vs other engines. Sellers will usually give me a VIN number, but not look under the hood for engine type. Can I determine the engine type by the VIN #? If so, what number(s) and position(s) would that be?
I like stick shifts, having had bad luck with a 1989 Camry's tranny that went out at 150k after driving it for only 10k miles, apparently due to prior owner's failure to change the transmission fluid regularly, or at all.
Also, any other tips for buying and maintaining one?
Are there any advantages of a Generation 8 over Generation 7?
How hard is it to remove and replace the timing chain?
Thanks!
There's 2 ways to identify the 1zz. There's a label from the factory on the passenger side of the head. The other way is to look at the certification label on the driver's side door jamb.
The later 1zz from 03-08 has a plastic intake manifold. Not sure about 98-02.
Are you in the US? All US 98-02 Corollas will have 1ZZ-FE's. Later ones (roughly 2000 model year on but I can't guarantee the cutover date) will have VVT-i.
Corollas sold around the world could have very different engines (which makes me think you might not be in US).
I have a 99 Corolla with non-VVT-i, burns no oil at all. None.
My wife has a 2006 Camry that needs a quart every 2500 miles. It is VERY hard to justify doing engine work when you can just add a quart every thousand or couple thousand miles.
140K miles on 99 Corolla, 150K miles on 2006 Camry.
Just money wise... if you have an engine that burns a quart every 1000 miles and you drive 12Kmiles a year, that's just $50 a year in oil. Hard to justify much work on a 15-20 year old car even if your labor is free.
If you price your own labor as free and are looking for something you can maintain easy for cheap.... this generation of Corolla has the most widely available and cheapest parts cost of any used car out there.
#9 ·
Hard to say. The Camry needed a new oxygen sensor about 100K miles but I don't think it was because it was burning oil. The Camry also got a brand new exhaust last year but that was rust, not catalytic converter damage from oil. Just my opinion: 1 quart every 2500 miles is not bad for a 15-year-old car. But it is in stark contrast with the 1ZZ-FE in the older Corolla that burns no oil at all.
