c151 trans id
4.4K views 15 replies 3 participants last post by  buzzbox
Hey all, hope everybody is doing well.
I am going to a junkyard today to look at a 5 speed trans. Does anybody know where to look for the trans identification number on the transmission itself? If so, what is the number for a C151. My 4 speed has a number by the boot for the release arm but it doesnt say 141 on it. Thanks for any help. Dave
Toyota rarely even stamped an ID on any of their transmissions and those that did were usually on the lip of the bellhousing and didn't spell out what it was.
Have to go with starter location, bell-housing, input spline count and length etc.
This article is on a C150 but will give you some ideas.
I know the spline count is the same on the 4 speed and the c151 but I dont know if the c150 is different. Add that to the list of things I dont know. hahah. I dont want to end up paying 600 for a trans that has a shorter 5th and a pop out issue. Hell I dont even know if the c150 would bolt up to my 5efe.
#13 ·
I'm not a tranny guy, but I took apart my 4 speed just to get an idea of how it works, and it looked to me the only way to replace the input and output bearings was to open the whole thing up. I had a 5 speed that was in bad shape and replaced it with a "low miles" junkyard unit. Sure enough it's low miles and runs great. I'm thinking I'll take the old 5 speed in for a rebuild at some point, these are becoming hard to find.
I guess that depends on the model of car it came out of. Note that the C150 was used in many models, each with a different bell housing (which is part of the case and not separate). And that included the Paseo with the 5EFE engine. So you could find a C150 from a Paseo which would likely be a direct bolt-on for your Tercel. I say likely because shifter cable mounting may be different and other little things like that. You could fix that by taking any C150 and swap in a Tercel bell housing. Trust me you don't want to try that yourself! But a good transmission tech could do it. The thing is, just to get the two halves apart, you separate them about 3/4". Then you have to reach in with a 10mm wrench and loosen a linkage nut. Then they come apart. Good luck reassembling!
Better to just find a C151 in decent shape, or have one rebuilt.
In my case I did a Nationwide junkyard search and was lucky enough to find one 75 miles away, so I went and picked it up. Installing the clutch was a trick because of the lack of pilot bearing. The crankshaft does have a slight depression, so the alignment tool sort of works if you're careful.
