Does the 7th or 8th generation Camry have any kind of smart charging system?
The charging voltage on my 2016 Camry LE seems to follow alternator temperature and not much else.
After a cold start the charging voltage is typically 14.2 volts which then drifts down as the engine and alternator warm up. The voltage generally levels off around 13.6 to 13.8 volts.
If the car is restarted warm after a brief stop, the charging voltage is no higher than 13.8 volts. I would like to see an elevated charge voltage for at least a short time to adequately recharge the battery.
Thanks for any information.
