camry has me stomped!!
2.7K views 16 replies 5 participants last post by  david36
this Camry is driving me crazy and ive had this prob on and off since 2011. 1995 2.2 starts fine and drives great in cold weather i can travel anywhere as longs as its pretty cool.but now this texas heat has come and so has the problem. driving in heat after a while will cause it to idle down even when i accelerate but idles fine when in neutral and park but not in D or R.
i read about 50 threads searching i replaced fuel filter cleaned IAC and replace frog face gasket,TPS replaced spark plugs and alot more and after about 500 bucks of parts and labor the problem still occurs..:help: any help or advice would be greatly appriciated!
replaced:
throttle position sensor.
idle control valve clean and gasket
fuel injector cleaner
replaced pvc valve
fuel filter
transmission shift solenoid.
spark plugs
cleaned intake manifold
yes so far ive thrown about 500 what makes it harder is that it never happens when i take it to mechanics and i try to show them the problem. the engine light does not come on and i havent took it to toyota stealership
Was the IACV checked? Or just cleaned? Also, was it properly reinstalled? Those things are tricky and SUPER touchy on these engines.
#13 ·
ive inspected the lines not to long ago didnt see any dry rot or slits. and yes i cleaned and replaced I IACV and frog gasket when i did so it ran better and didnt idle as rough and i also took it to austin after doing that (4hours away)
