Can I use API SP 5w30 oil in my 2007 Avalon
1.4K views 12 replies 5 participants last post by  msinapi1
Even though SP oil is backwards compatible, is it backwards compatibility all the way to SL?
I read modern chemistry might not be adapted or compatible with older engines. I know you can't put modern oil in a model T for example.
That brings up another issue I came across, not to use anthything better than blended oil in our engines. Something about long term use of full synthetic and seals. So i am not taking a chance. To me blended is better than OEM and I still change oil at 3k. I think the interval of oil change is the most important thing with oil.
The 3.5 Duratec is a 2017, my Avalon 3.5 is a 2011, and the 5.4 Triton 3V is a 2008. The Duratec I ran Motorcraft Synthetic blend in under warranty, didn't notice it made much noise any ways so little difference in going to QS FS. The 5.4 3v is a remanufactured (so new) engine with upgraded components timing components and various other problematic parts, I ran conventional for the "break in" as recommended by the remanufacturer and switched it to QS FS after the break in was supposedly over, didn't notice a change in sound other than during the break in period which I don't attribute to oil. My 3.5 Avalon had 5w30 Mobil 1 it's entire life until about 120k when I switched it to QS FS, it is noticeably quieter outside and also in the cabin with the radio off running the QS FS.
#13 ·
I did more research found out the full synthetic oil (OLD formula) use additives that would swell seal on older cars. This is no longer true. Supposedly they changed their additive package. It is now supposed to be safe for older cars. Thanks for your feedback.
