Change beep volume when locking highlander
37K views 6 replies 6 participants last post by  Jeff M
Does anyone know how to change the beep volume when you lock the car,I press the button on remote and can hardly here it,just a low beep,does not sound like it's the horn,there must be a setting some where to activate the horn.
There's no way to make it use the horn (your neighbors will be thankful). You can increase the volume of the beep from the default of 5 up to 7. Also, the emergency lights should flash. The setting is in the nav under Settings -> Vehicle. For some reason, you have to have the ignition on and put it into drive.
