The gasket between my exhaust manifold and my exhaust pipe is leaking. You can put your hand near it and feel it coming out, and my engine is very loud.
I no longer have the stock cat, my new cat is welded in place and does not use the gaskets from the original style cat.
I went to the parts store, and the gaskets they have say they are for the cat converter. Those were the only exhaust gaskets they had. Is this the same gasket I need to use to replace the one between the manifold and exhaust pipe leading to the cat?
Or, was the pipe between the manifold and after the cat once considered the "catalytic converter" by Toyota and all one unit, and when I had the new cat welded in, they just cut out the important part and welded in the new one?
