Hi guys,
I have got a problem with the clutch on my '88 camry. Here are the symptoms:
1) Clutch pedal frequently gets stuck when depressed. Does not come back up off the floor. Have to pull it back up by hooking foot under.
2) When I take the top off the master clutch cylinder I can see the fluid level go down slightly when the clutch is depressed (~5mm). There is plenty of fluid.
3) I can see no clutch fluid leaks.
4) When the pedal is pumped the slave cylinder does not move.
So obviously its a problem with the clutch hydraulics rather than the clutch itself.
But is it the master or the slave cylinder?
Cheers,
Jack
Cheers,
Jack
