Hi all, I have a 94 celica that had a busted ignition coil. the car would hesitate under load and was hard to get up to highway speed. After replacing the coil with a junkyard one, the car started up fine but died on the highway. When I tried to start it again I got a code 12 crank no start.
This was weird to me because I already tested for opens/shorts on the wiring and the car started ok before. I had also already checked the resistance across the G and NE circuits and they both read in spec. However, I just tested them again after the car started and then died, and the NE circuit is 1100 ohms! way out of spec. So what I'm thinking is when the dizzy gets hot the pickup fails, but will start ok cold. I pulled a junkyard coil that also reads good and swapped over all my known good components and I'm hoping it starts and runs now. Will update. Anyways thats the hot tip (wasn't able to find this on the forums) is if you have a code 12 crank no start intermittently, check the resistances on the distributor just after loading up the circuit/getting it hot.
