So here's the problem... ('99 Camry, 4-cyl, LE, auto)
When it's cold (under 20 degrees or so) and the car has been sitting for a while (6+ hrs) it will barely move forward until the car warms up a bit. At first I thought it was engine components contracting just enough (and really worn rings) that I was loosing compression until it heated/expanded.
However, I realized that I could go in reverse pretty much with the same power as normal (maybe a little sluggish/weak). It only when I would put the engine in any of the forward drive gears that I would have the problem. The engine revs just fine, but there's zero or virtually zero forward propulsion until the car warms up a bit. Once the car begins to warm the power will increase with the temperature. When it gets to normal operating temp everything is just fine and actually runs really smoothly.
It's been too cold the last few days to check the tranny fluid, but I will once it warms up in a day or two (or when I find an underground parking garage) I will. Could my trouble really just be caused by low and/or old tranny fluid or is this a sign of something more serious?
Oh, and I'm taking a trip to Montreal in about a week, so cold weather reliability is definitely an issue.
Thanks.
Thanks.
