Hey guys. whats the best way to convert my ae95 to rear wheel drive. looking for something easy to do so my cars is better on gas and more powerful.
Its 4WD for your information.
Converting a car like that would cost tens of thousands of dollars and you would never make it better on gas and more powerful at the same time, sorry to bust your dreamsHey guys. whats the best way to convert my ae95 to rear wheel drive. looking for something easy to do so my cars is better on gas and more powerful.
wow, it doesnt seem like your experienced enough to even consider undertaking a project of this magnitude, this would take an experienced automotive fabricator thousands of dollars and a ton of headaches trying to get things to fit right ... first off you need to build a tunnel under the car ... secondly, you need to build brackets to support everything (such as tranny, engine, driveshaft) , then u need to modify the rear end to accept the axle ... this all requires frame modification and heavy fabrication, and non of this would give you better gas milage or more power (im guessing your saying horsepower ... when u say power, that is a tell tale sign of a newbie, you should talk in terms of horsepower and torque not the general power)Hey guys. whats the best way to convert my ae95 to rear wheel drive. looking for something easy to do so my cars is better on gas and more powerful.
yeah i get around 20mpg. around 8km litre.How many MPG do you get right now? I'd say just live with it if it's over 20. (I'm guessing you guys go by Km per Liter?)
Haha yeah. i have a 4A-F carb though.Well if you had more power, 4-wheel slides would definitely put a smile on your face...
You could look at that 190hp 4afe thread somebody else has going on, and do the same with your car.
4age > 7afe.....
I wouldn't actually pull the front joints from an ae95....
it's been done on many subarus.... however, the drivetrain in an ae95 is NOT the same as a subaru.... if you had a celica alltrac, which like the subarus, has a full time AWD setup...
the ae95 is electronically selectable.... further, the bias is actually 60/40.... so, 1) you don't have 23hp per wheel... and 2) you should be able to turn the rear wheels off and you'll only lose MPG based on drag from the diff and extra weight of the vehicle....
There's a possibility that the electrinics will have a problem with you not having any load on the front wheels if you were to pull the axles & leave the joints.
the tunnel in an ae95 is much larger than in an ae92..... if you would have to modify it, good possible chance that a good hammer would do the trick... a T50 isn't that big of a transmission....
I live on a dirt road. i would like rwd so i could drift and do burnouts haha.only 170 km/h, lol
its more than necessary if you goes on dirt and now road, believe me
Even with a swaybar they have more body roll than Rita Macneil dancing.if they did'nt have a sway bar on the AWD version, it would be outright dangerous to drive that car fast
