Hello, I recently changed coolant, and had thermostat replaced. Now my cooling fans do not work. The temp gauge stars in the middle of the gauge then steadily works up to the H. It cools down when turning on AC, and heat on full blast.
I also turned the ac off, and unplugged the radiator fan switch on the radiator, and they both came on. Also, are these cooling fans supposed to help burp a coolant sytem as well? I checked the fuses(RDI and CDS) too, and they were fine. I read up that the fan motors can fail if the car overheats, but both work after unplugging electrical from the switch on bottom of the radiator.
Need help.
Need help.
