I just bought a 97 Camry LE v6. It cranks but doesn’t start. Timing belt is good, relays are good, (I checked continuity I think that’s what you are supposed to do. Also when I plug in the EFI relay, some clicking noises start by the injector fuel rail and around) Fuses bought brand new, fuel pump works. I believe it to have a short, I am not sure as I am only 17. Can anybody help me. Also the check engine light is on, but the OBDII port doesn’t work. It keeps telling me to make sure the ignition is on. And it only has 4 wires connected to it. Could the neutral safety switch cause this??? I know the motor isn’t getting fuel because I can’t hear the pump priming. I tested the pump using the battery itself. Could the neutral safety switch cause it to NOT send any fuel??? Please help I want to learn and it’s my first car.
