Some experienced help would be appreciated.
Camry 2001 w/ I4 engine.
I'm trying to diagnose a friends engine problem. The ECU was announcing an error code of P0335, which translates to the Crankshaft Position Sensor. On inspection the 10mm bolt holding the sensor was found to be loose. After tightening and clearing the code, no improvement.
The sensor tested to 2K ohms, where a new sensor showed 1.3K. So, after much fiddling I got out the old sensor. On looking at the sensor, it was clear that the toothed wheel had been grinding away at the sensor for a while, which probably explains why it went bad.
Photo here: https://onedrive.live.com/redir?res...edir?resid=2DB423FFB1F8BE5D!42315&authkey=!AN6bfYHK2JZJICE&v=3&ithint=photo,jpg (can't seem to link the photo in directly).
I installed a new CPS and it shows the correct 1.3K resistance and 450ma AC (on multimeter) when cranked. Still no start (no fuel, no spark).
The diagnostic machine shows 0 RPM when cranking. Not sure if the ECU shows correct RPM when cranking. Anyone know for sure? That piece of information alone would be really helpful.
Possibilities:
* ECU fried by the damaged sensor?
* Toothed wheel damaged by sensor?
* Something else?
Any help greatly appreciated.
Possibilities:
* Something else?
