2005 Toyota Corolla
I've had the air bag red light on my dashboard for awhile so finally I found the solution: replace that air bag crash sensor right under the battery (the one with the yellow connector. There's one on each side but my B1615 code is for the LH left-hand, so I'm assuming that's the driver's side.
The problem is the bolt is rusted in, so I used a dremel disc and cut a line down the top of the bolt head. I got the sensor out but the bolt is still stuck there. The top of the bolt turns if I use a pair of pliers but it's not coming out. I put my finger through the pre-drilled hole on top of it and it feels like there's a holding nut on the other side.
Is there a trick to getting this out? What can I safely cut without destroying my ability to put in a new bolt? There's not a lot of room to maneuver the dremel from the top or bottom. A used TRW sensor is 40 bucks on Ebay.
Please see the pictures.
